Question about Whirlpool GHW9400 Front Load Washer
One minute left
The washer says 1 minute left, but it just keeps going for 15 min or half an hour after that! Overall it takes well over an hour to finish a load.
    Genius:
  • 1,028 Answers
Be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Posted on Nov 10, 2008
SOURCE:
How long does it take to drive from Montana to Las Vegas
13 hours, 21 minutes
The driving time from Great Falls Montana to Las Vegas Nevada is
25645215-namh4xdyvtmbnfjkezl10utl-2-0.jpg 410-412 5th Avenue South, Great Falls, MT 59405, USA
988 mi - about 13 hours 27 mins
1. Head east on 5th Ave S
223 ft
2. Turn right at the 1st cross street onto 5th St S
0.4 mi
3. Turn right onto I-15BUS/MT-200 W/US-89 N/10th Ave S
Continue to follow I-15BUS/MT-200 W/US-89 N
2.0 mi
4. Keep left at the fork, follow signs for I-15 S/Helena and merge onto I-15 S
148 mi
5. Take the exit onto I-15 S/I-90 W toward Butte
8.0 mi
6. Take exit 121 for I-15 S toward Dillon/Idaho Falls
0.7 mi
7. Continue onto I-15 S
Passing through Idaho
Entering Utah
377 mi
8. Keep left at the fork to stay on I-15 S
35.7 mi
9. Keep left at the fork to stay on I-15 S
Passing through Arizona
Entering Nevada
415 mi
10. Take exit 44 for Washington Avenue toward D Street/City Parkway
0.3 mi
11. Turn left onto D St
0.2 mi
12. Turn left onto W Bonanza Rd
Destination will be on the left
0.6 mi
500-546 East Bonanza Road, Las Vegas, NV 89101, USA
Apr 13, 2015 | Miscellaneous
Why does my Kenmore HE3t front load washer always take more time to finish then what it says on the timer?
Check the filters in both ends of the hoses. If they are clogged, it will throw the timer off. If it figures on 2 minutes to fill but it actually takes 6 or 7 minutes, the timer won't be accurate.
Jan 20, 2013 | Kenmore Elite 45986 Front Load Washer
I have intermatic TN311 MODEL TIMER IDK HOW 2 WORK I WANT IT TO COME ON AND OFF FOR 15 MIN EVERY HOUR FOR 12 ORS A DAY IS THAT POSSIBLE AND HOW
Open following link to identify TM311 timer:
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
1) First of all, you would need more turquoise 107TN222 ON and red 107TN221 OFF trippers.
2) BUT big problem is that TN311 time dial is divided into half-hour segments, so minimum on-off is probably 1 hour since it takes 2 trippers for on-off cycle, and width of 2 trippers is same width as 1 hour.
3) Open following link for plug-in timers with 15 minute segments shows Woods 49664 & Stanley 31192 & Sylvania SA110
http://waterheatertimer.org/Woods-timers-and-manuals.html#49664
4) Notice the 49664 dial, that each hour is represented by 4 segments. This says timer on-off period is 15 minutes.
To set this timer, you would pull up all segments around the dial, and then push down 1 segment for each hour that you want timer to turn on for 15 minutes.
5) TN311 has 3 prong grounded outlet, Woods 49664 has 2-prong outlet.
6) Stanley 31192 timer and Sylvania SA110 have 3-prong grounded outlets and 15 minute intervals.
7) You cannot accomplish 15 minutes intervals for 12 periods a day with programmable digital timer.
Most digital timers allow 1 minute program times, but are limited to 6 or 7 programs, and not the 12 separate on-off periods needed for your project.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 18, 2011 | Hardware & Accessories
F-28 flashing. Door will not open
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
Check your washer plug to see if the connections are tightly screwed. You can also plug off for half an hour to reset.
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I own a 2001 Olds Alero. Sometimes the engine
to reset the pas-loc turn the to on position 10 to 15 min.then turn the key off for a few seconds,then start the car/if your security light is on do this like i said for 10 to 15 minutes.the light should go off,then turn the key off and wait a moment then start it,you dont have to wait the 1/2 hour out
Dec 12, 2009 | 2001 Oldsmobile Alero
Have 1-min on the digital display. wait 15
It sounds like you have a restriction going to the pump.You have a filter which needs to be cleaned.
Nov 10, 2009 | Whirlpool GHW9100L Front Load Washer
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Whirlpool GHW9400 Front Load Washer Logo
250 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
