You should be in time keeping mode to do this. The manual say's press the "A" button for 5 seconds not 3 seconds. "A" button should be pressed until you hear 2 beeps (5 sec), if you only hear 1 beep (3 sec) don't let go of the "A" button, if you do you certainly will not be able to change the time, zone, dst, date, etc...
SOURCE: casio g shock
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: setb time for casio g-shock
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
SOURCE: need help in setting the
Hello
I want to clarify first: You can set it into correct time but eventually it won't stay on the correct time? Have you tried exposing it to direct sunlight for a few minutes?
How do I set the time on casio g shock 5121
I can't set the time on my casio 5121 GW-3000B
How do I change my casio 5121 GW-3000B to time keeping mode
