you need to remove the inner door panel, you will see a plastic sheet ,, peel that back,, look through the inner door metal, towards the outside handle, Little plastic clips hold on the rods that control the handle mechanisms , these need to be removed,, once thats done,, you will see the small bolt heads that hold the handle in place,, remove those, and the door handle will slide out,, ( on the outside of the vehicle .
The locking mechanism is manufactured with carbon composite and plastic levers
that the door handles attach to. It is hard to tell what parts that you do need.
Remove the passenger side door panel. It will have some screws and maybe a bolt
on the inside handle. The panel has snap plug on it and they fit into designated
hole in the door. After getting the door panel off, be careful here, there are
sharp metal edges that can cut. There are some peep hole to see the rods and
connector inside the door. If the plastic hooks on the door locking mechanism
are broken. The hole door lock assembly will need to be replaced.
Try your local wrecking yards and tell them what type of vehicle you have and
year. Also, state what door it is and what you will need.
Now, if the interior door hand hook on the lock mechanism isn't broke off.
The get a cloths hanger and straighten it out and attach it to the opening latch
on locking mechanism. This will give you inside temporary handle, while you are
trying to fix the door. Safety. GB...stewbison
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
Inside of the door there are rods that connect from your inside door handles to the the latch mechanism. The rods are connected to both the handle and the latch with plastic clips. To check you will have to remove the door panels and see if the rods are attached or if the plastic clips are broken or missing. The clips are a very cheap part to replace. Any local auto parts store should have them in stock. Also very easy to install. Hope this helps. Happy motoring.
Hi, take the inner door panel off, look around should be a rod that goes from the outside handle to the door latch mechanism, its either broken or unhooked.
This is how i solved a similar problem.
When I removed the door panel and looked inside I was able to see the small rod that attaches to the outside handle was not connected. I tried to snap it back in but it wouldn't stay so I pulled the rod over where I could see that the small plastic part on the end of the rod that holds it in place had one side snapped off. Should be easy to fix once I locate the part. Just did this today and haven't looked for the part yet.
It sounds like it could be the plastic connecting bit that links the outside door lever to the rod that operates the door mechanism, has broken or become disconnected. To check, you will need to remove the trim on the inside of the door, after removing any screws and the inside door lever and window winder. However now that the child safety lock has been set it could be very difficult to get the door open.
All I can suggest is that you look at the other rear door to locate the position of the safety tab and then try to disengage it by using a suitable thin blade or something on your bad door so that you can again use the inside lever.
Once you have the inside trim off and the plastic sheet, you will see an access hole for the door mechanism and the outside operating handle of the door. It should be attached to the actuating rod by the aforementioned plastic bit. If plastic bit appears OK try re-attaching it or replacing it if broken. If the part of the outside handle which attaches to the rod is broken the handle will need replacing.
It sounds like the plastic connecting bit that links the outside door lever to the rod, that operates the door mechanism, has broken or become disconnected. To check, you will need to remove the trim on the inside of the door, after removing any screws and the inside door lever. However now that the child safety lock has been set it could be very difficult to get the door open. All I can suggest is that you look at the other rear door to locate the position of the safety tab and then try to disengage it by using a suitable thin blade or something on your bad door so that you can again use the inside lever. Once you have the inside trim off and the plastic sheet, you will see an access hole for the door mechanism and the outside operating handle of the door. It should be attached to the actuating rod by the aforementioned plastic bit. If plastic bit appears OK try re-attaching it or replacing it if broken. If the part of the handle which attaches to the rod is broken, the handle will need replacing.
You will need to remove the inside door trim panel and check the three (3) rods and plastic connectors that connect:
(a) the inside door handle to the door mechanism
(b) the inside door lock knob/outside key lock cylinder to the door mechanism
(c) the outside door handle to door mechanism.
Most likely one (or more) of these rods have either become loose or the plastic lock clips have broken.
The "L" end of the rod goes thru the hole of the clip and the clip has a pivoting "U" shape that goes over and locks onto the rod.
Based on the your year (2000) it might be a good idea to remove all clips and rods; and remove the entire door mechanism. Inspect, clean, lubricate, and re-install it.
I had this happen as well on the rear doors, and on both sides now. The door panel is easy to remove, the problem is accessing the bolt nearest the rear of the vehicle because the entire locking/door latch mechanism is in the way. At the factory the door handle was obviously installed through that hole first before the locking mechanism/latch went in.
To remove the door panel, pop out the two plugs pieces in the pull handle, then unscrew the screws there. There is another screw in the opener handle of the door and two more around the edge of the plastic frame (one on side, one on bottom). Once loose disconnect the handle by un-clipping the plastic pieces from the metal rods. Then pull the door loose my going around the edges and popping out the plastic retainers. The electrical connection is easily unplugged so you can remove the panel completely to get it out of the way.
