Canon DR-3010C Pass-Through Scanner Logo
A
Anonymous Posted on Mar 29, 2012
Capture perfect error 4523
1 Related Answer
A
Anonymous
  • Posted on Mar 09, 2008
SOURCE: Canon Unknown Error
Please run Scandisk on your computer. If the problem persists even after this, reinstall OS. You need to reinstall other applications also.
S. Mohan
How many gallons are in a tank 12" in diameter x 40" long?
Radius square x pi = area of circle
6" x 6" x 3.1415 = 113 square inches
113 square inches x 40 inches = 4523 cubic inches
231 cubic inches in 1 gallon
4523 divided by 231 = 19.58 gallon
http://waterheatertimer.org/pdf/Water-heater-Formulas-and-terminology.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Can't change dpi or mode in scanner settings on capture perfect 3.0
Remove & re-install 9080 driver & Capture Perfect if the driver doesn't fix the issue. Verify you have Administrative rights to the computer as well
Need a code for my philips to reprogramme my sky remote my model is 28pt4458/05
Try these codes.
0081
584 065 040 041 582 221 115 071 351 402 034 219 451 371 035
Philips
14PT3685/05 21GR2550/058 21PT532A-05 21PT161B-05 21PT166A/03 MD12E 29PT828C/05 32PW9615/05 28PW6322/05 32BW6332/25 28WVRN 32PW952505 SL6-1 25ST1761 25PT727B/05 21GR2554/05B 28PW6606 21PT161A105 32PW9566/05R TW6328 28MD12E 28PT/4523/25 32PW9525C 28PT4521 24PW6006/05 32TW6517 32PW8515/05 32PF99445/12 42PF9945/12 21PT5505 23PF99445/12
Philips
20PV164/05 20PV230/07 24PW632405R 25PT4475/05 25PT4523/05 28PW6516/05 28PW5324/05 28PW6315 28PW6515 29PT9113-05 29PT828C/25 32PW6322/25 32PW631S 32PW6517 32VW6005 32PW962B 32PW6006/25 32PW6526/05
I need vedio capture driver for ati wonder tv tuner
The video capture software is already included in the CD that comes with the Video capture card... But if you needed an alternative software, try Ulead Video Studio 7, works perfectly on me.
I dont have the disk for my web cam GE 98090 how can i get the driver ?
It says that it doesn't need a driver since it follows a universal driver included in windows. GE Perfect Image Webcam (1.3 Mega Pixels) Our Products: GE Computer Accessories > GE Webcams 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg2.jpg GE Perfect Image Webcam (1.3 Mega Pixels) (Click to see larger image and other views) hs.align = 'center'; hs.transitions = ['expand', 'crossfade']; hs.outlineType = 'rounded-white'; hs.fadeInOut = true; hs.dimmingOpacity = 0.3; //hs.numberPosition = 'caption'; if (hs.addSlideshow) hs.addSlideshow({ slideshowGroup: 'slides', interval: 3500, repeat: true, useControls: true, fixedControls: false, overlayOptions: { opacity: .75, position: 'top center', hideOnMouseOut: true } }); function pcf_initEnhancement(ele,img) { if (document.getElementById('1')==null) { hs.expand(ele, { src: img, minWidth: 250, minHeight: 250 }); } else { document.getElementById('1').onclick(); } } SKU: 98090 Capture clear videos and sharp images with the GE Perfect Image Webcam. More details... Price: $54.99
icoaddtowishlist.gif icotellafriend.gif addthis_pub = 'jascoproducts'; addthis_brand = 'Jasco Products'; addthis_options = 'favorites, digg, delicious, myspace, facebook, google, live, furl, reddit, twitter, ask, technorati, stumbleupon, more'; icobookmarkshare.gif Product Details Capture clear videos and images photos with the GE Perfect Image Webcam. Capture high quality hands-free audio and broadcast through the built-in microphone. The stand can easily be adjusted to your desktop or clipped to your laptop or monitor. Complete with ArcSoft® VideoImpression™ and PhotoImpression™ editing software to capture, edit and customize images and videos.
Features:
  • Built-in microphone
  • Snap shot button - Easy to use for great still photos
  • Hassle free focus - Ensures crystal clear videos with adjustable focus ring
  • ArcSoft® Editing Software (Included)
  • Adjustable stand - Steady base ensures stable videos
  • Compact size - Provides convenience and portability, perfect for travel and laptop use
System Specifications:
  • Sensor: CMOS with 1.3 MP
  • Resolution: up to 1280x1024
  • Video frame rate: 30 frames per second
  • Color depth: 24 Bits, RGB True Color
  • Focus range: 10 cm -- infinite.
System Requirements:
  • Computer with USB port
  • 350 MHz recommended
  • 64 MB recommended
  • Windows® XP SP2 or Vista
  • 100 MB free hard drive space
  • 16 bit video display or higher
  • CD-ROM Drive
  • Universal Video Class no drivers
1helpful
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
Won't scan to PDF with Capture Perfect 2.0; Error
There are two versions 2.0 and 2.3. One of them converts to PDF without PAFCV2.dll load error. Try and down load from http://software.canon-europe.com/software/0022439.asp?model= Incase this doesnot work, you need the other version.
I generally dont do direct conversion to PDF. I clean the images, create multipage and then convert to PDF and hence don't know which version works. I have both versions. Incase the downloaded version does not work, pls send a mail to [email protected] I shall send you a copy.
Canon Unknown Error
S. Mohan
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
old marine
old marine
ZJ Limited
ZJ Limited
