Question about Toshiba Satellite L455D-S5976 Series Laptop Auto Car Adapter (C1965UM310071E954)
How do i get my laptop to power on? Have new power cord but still will not power up
Power cable was damaged and would not charge properly. Bought new power cable and let charge for a couple days. Still will not power up. The light flickers for the power cable indicator but no other lights work either. Should still power up when plugged in even if the battery is junk right?
    New Friend:
There is a possibility that if the battery is shorting out it won't hold the charge or let it power up.
Posted on Mar 30, 2012
3 Suggested Answers
SOURCE:
  • 1288 Answers
SOURCE: my toshiba laptop p10-792 turns
Could be a few things:
I'd start with checking the security of the DC jack on the laptop, if it feels loose or sloppy, it is not making good contact with the motherboard and eventually it will spark across the internal terminals and damage the motherboard, needs replacing.
If that seem ok, get a multimeter, set it to DC volts at 20volts and touch the RED probe to the inner part of the ac adaptor plug (the bit that goes into the laptop), and the BLACK to the outside of the plug.
See it gives a constant 20 volts, if not (or the indicator light on the adapter flickers or pulses, then it is most likely a dying adapter (replace this).
If both the above are not the problem, then you have a more serious powerboard problem. Trying it on battery alone and then on mains alone will give some indication which is causing the fault, if both are giving you the cutting off problem, then you will need to have the laptop stripped and checked.
Posted on Jul 05, 2011
Testimonial: "Great...."
  • 16 Answers
SOURCE: The power cord is basicly
Sounds like you need a power cord - best option is to take the busted cord to The Shack (radio shack) and they have a universal power cord and they will help you match the tip so it fits in the laptop. I've done this for MP3 players and other devices and only costs about 30 bucks. Otherwise you could try hunting ebay or craigslist to find a replacement, or use some electrical tape to hold it in place that it works.
Posted on May 13, 2011
Lenovo idea pad won't charge or run plugged in
Is the cord and Battery the EXACT same power spec? If so, it may be the AC jack in the Laptop has been damaged due to pulling on the cord while plugged in, broken connection.
Apr 06, 2013 | Lenovo IdeaPad Y450 Notebook
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
My computer won't turn on or charge.
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
Sep 30, 2010 | Toshiba Satellite A85-S107 Notebook
My Presario CQ50 won't turn on even when plugged in. Battery charge light flashes, but no other lights come on. Do I need a new battery?
Most likely issue is that the cord has been damaged, or that the power jack has become loose.
First step is to remove the battery and try plugging in. If the light comes on, on the front of the laptop, your battery may be dirty or defective.
If the unit will still not power, you will need to test your cord or look into a new cord. If the cord puts out the proper 19v (give or take .5v) then the issue lies with the laptop jack. Otherwise a new cord will most likely do the trick.
-Halfs
Aug 12, 2010 | HP Compaq Presario CQ50-110US Laptop
Laptop won't turn on even though it's charging.
Check Output DC Voltage with a multimeter.. if output is not proper.. change output cable with socket... contact your nearest electronic serviceman
May 29, 2010 | Computers & Internet
Bought a new power cord because I had to keep moving cord around to get battery to charge, move and would lose charge received new power cord and still have to move cord around to keep getting a charge...
First thing you need to do is STOP trying to wiggle the cord to make it work. You could damage the motherboard.
The power jack needs to be replaced. It's a pretty standard repair. You can try finding a local laptop tech from Craigslist or visit your local shop.
This type of repair usually runs 70-100 out the door (depending on where you live)
I don't recommend you trying to fix it yourself.
Apr 03, 2010 | Dell Inspiron B130 Notebook
Power cable end had red, white and Black wires came of the pin holes
You probably shouldn't attempt to repair the cord. I would suggest you purchase a new power cord (they aren't too expensive). You could really damage your laptop if you incorrectly insert the wires.
Apr 25, 2009 | Computers & Internet
Power connection trouble
It sounds as if the power pin (where the AC cord connects to the computer) has become unsoldered. To fix it usually runs $100-200. Because the connector pin is so fragile, the damage to the pin is caused by the day to day tugging and pulling on the power cord.
What you needed when you got the computer is a cable stay or cable retention device like the Jerkstopper. It takes up the strain when you yank or tug the power cord and minimizes the damage to the power pin. It's a very common problem with laptops.
Here's a short video that talks about the problem. . . .
May 29, 2008 | LG X-Note LM50 Notebook
My Vista Laptop immediatly shuts down after i pluck out the power cable.
It sounds as if the power pin (where the AC cord connects to the computer) has been damaged. The part to fix it usually runs under $10 but the labor is gonna set you back $100-200.
What you needed when you got the computer is a cable stay or cable retention device like the Jerkstopper. It takes up the strain when you yank or **** the power cord and minimizes the damage to the power pin. It's a very common problem with laptops.
Apr 20, 2008 | Toshiba Satellite 2410-S203 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Open Questions:
See all Toshiba Satellite L455D-S5976 Series Laptop Auto Questions
Toshiba Satellite L455D-S5976 Series Laptop Auto Car Adapter (C1965UM310071E954) Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
