SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
SOURCE: hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
SOURCE: Sir, i have a life fitness
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message [email protected]
