I need to program my oven to do a timed bake option tomorrow. I want to bake some potatoes for 1 hour, 15 minutes at 325 degrees; starting to bake at 11am and ending at 12:15pm. Please advise on how to do this. I have misplaced my owner's manual.
Thanks -- Connie Beckman
Connie,
Found the owners manual but it was worthless didn't have the control board information.
Found the control board and it used in quite a few other makes has same functions on all the units.
So here's my best answer not your unit but is the same control board..
Sure hope this helps!?
https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/1201522L.pdf
Best to you.
SOURCE: need manual
Click on this link and then look on the rifgt and click on guides and manuals. that will take you where you want to be. I hope this helps. http://www.frigidaire.com/products/cooking/built-in_ovens/single_gas/prod_FGB24L2A.asp
SOURCE: Frigidare double convection self-cleaning oven
try here kim if you dont find what you need contact me back http://www.frigidaire.com/support/manuals.asp
SOURCE: door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
SOURCE: oven not working
It is most likely that the oven heating element has failed, which would be the likely source of the 'bang' you heard, you may also need to check the oven temperature control sensor as this may have gone out at the same time.
