Please send the answer how to fix the problem of hp laserjet m1005 printer. as soon as possible.. thanks.
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
SCAN HEAD MECHANISM
Hi sir 1005 06 scanner error ple help
For scanner error 6. . . . . you must replace scanner refurbishing kit....100 % guaranted solution or else contact 9922030490
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
Memory overflow error 20 Solutions for "error scanner 20" problems in HP LaserJet M1120 MFP
SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
SOURCE: Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
SOURCE: Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
