SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
I think your camera is not compatible with the SDHC card you bought. Check this: http://panasonic.jp/support/global/cs/sd/connect/dsc/dsc.html
SOURCE: will a SDHC 4G card work inthe c875 camera ?
i don't know if you got my last post (pc playing up,im not going to tell you its the user :))
the answer is no you can only use upto a 2 gig card on this camera
(did a search on the kodak website then phoned them up for you and that's their answere)
SOURCE: I bought a 4g SDHC card for my camera canon powershot sd400.
Well, first of all, I'm not exactly an expert on this, so please don't rely solely on my response.
It's possible that it needs an SD card, not an SDHC card. SDHC cards are high capacity, and some cameras just aren't able to use them because they're set up for the plain SD cards. Does it say what kind it needs in the manual? I think, if it's an older camera, I'm not sure what age exactly, they can't use SDHCs. Like I said, I'm not an expert, so you might want to get more info, if you can. Hope this helps.
your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
