Question about Honda Mmd 5000 Watt Electric Start Generator W/ Engine Ngk 6000HE
Honda 5000 generator with remote starter running rough.. tis like ******* or something.. oil was almost empty so i stopped generator and added oil and restarted.. can u give some advice as to how to remedy this problem
  • Robert K Mar 29, 2012
    my honda generator 5000 is brand new bought in September 2011 with a remote start installed. To clearly explain the problem I hit my remote button it started and after about 15 minutes it started puttering off and on so I turned it off and put oil iin the generator since it was near empty than the engine kept puttering. What could i do to remedy this problem without paying more money. I paid $5200 for it which included the remote starter. We live off grid and this is our source of power and it runs about 8 hours a day...i would appreciate any help you can give me we saved up our money to get it and probably couldnt afford to have it serviced.
    New Friend:
  • 118 Answers
Those generators are set up with a low oil saftey but your gonna want to check compression anyways just to verify it is where it needs to be. Im gonna guess its to be between 120-160 psi, check your manual for the service limits. after that check your air filter, valve lash, fuel filter etc etc.
Posted on Mar 29, 2012
3 Suggested Answers
SOURCE:
Mike258
  • 1498 Answers
SOURCE: I have a brand new
If I remember correctly this model does not use a fuel/oil mix. Please confirm this.
If what you are saying is that in filling the device with gas and checking the oil level, both overflowed, then we are good.
As you have done, drain both to their proper levels.
Now pull the spark plugs, they are most likely fouled with oil.
Turn the generator over a few times to clear the cylinder of excess oil.
Give the plugs a good cleaning. You may need to replace them. I just have a thing about tossing something with life still left in it.
Put the plugs back in and fire it up.
Best regards
Mike
Posted on Sep 03, 2010
MNfisherman
  • 11896 Answers
SOURCE: honda 5000 generator clear oil out leaking thru
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Posted on Oct 05, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
It starts with the switch fine but when i let go of the key it cuts off
Check for faulty low oil sending unit or oil level low or dirty oil (some generators have a fuel cut-out solenoid at the carb ). Key switch will override the low oil safety. Easy test, remove wire from oil sending unit. If unit runs, and oil has not been changed in a while, service engine and retest.
Sep 09, 2011 | Mi T M MiTM Generator 9hp Honda 5000 Watt...
Could low oil stop it from starting
Honda power products (generators specifically) are designed to shut down when low on oil. Adding as little as a tablespoon of oil will allow them to run again. It is possible that they could put this system in a motorcycle. But it is normally only used in stationary engines. Try new plugs. If the plugs are wet you may have just wet fouled them.
Nov 01, 2010 | Honda VTX 1800 Motorcycles
Honda 5000 generator clear oil out leaking thru air intake
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
How to fix a genset 6500 generators that stops when you turn starter switch loose?
Check the oil level or any other alarm that can stop it.
The switch may have lost its middle stable position and drop directly to stop.
Try after you have the switch up for starting, let it easy back in middle position. If there it stops again. Try to move the switch down to "Stop". You should hear a click. If not replace the switch with the same type.
Jun 10, 2010 | Watts Onan Portable Generator - 5000 ,...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
Honda Mmd 5000 Watt Electric Start Generator W/  Engine Ngk 6000HE Logo
183 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
