The Red light comes on, and thats as far it goes. on my 40 inch LCD Model TLA-04011C!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!The Red light comes on, and thats as far it goes. on my 40 inch LCD Model TLA-04011C!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
When the tv is turned on the picture comes on for a second then shuts off. Blue light stays on. When the tv is turned on the picture comes on for a second then shuts off. Blue light stays on.
yes my polaroid 40" hdtv when u turn it on the blue light comes on but no picture model # tla-04011cyes my polaroid 40" hdtv when u turn it on the blue light comes on but no picture model # tla-04011c
You can't post conmments that contain an email address.
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
Have you misplaced your Polaroid TLA-04011C LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid TLA-04011C LCD TV Users Guide? Follow this link (& click FREE) to download a pdf version of the operations manual.
Have you misplaced your Polaroid TLA-04011C LCD TV Service Manual?
Would you like a digital, searchable version of the Polaroid TLA-04011C LCD TV Service Manual? Follow this link (& click FREE) to download a digital version of the service manual.
First turn on and check with flashlight 2 in. from screen and see if there is a picture. If no picture then open back panel door by taking big black screw out of middle and 2 screw at bottom of panel and slide panel downward, pull off and unscrew metal plate and you should see bad caps in this set, this is what have to be replaced.
Have
Would
LCD TV Service Manual? Follow this link to download a digital
Would you like a digital, searchable, pdf version of the Polaroid TLA-04011C LCD TV Users Guide? Follow this link to download a pdf version of the operations manual.
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
The most likely the TV has a power supply related problem or it maybe just a blown fuse inside the TV.
I can't say it's 100% the problem because I can't actually look at the tv over the internet. If by some chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
Yes my TLA-040 did the same thing, it was operating normally and then it shut off. The red light comes on but no blue power on light at all. HELP
Won't power up.
when i turn on the screen the TV works fine for about 30 seconds and then the screen goes black. the LCD light is still blue
is this a problem with the bulb or the whole TV?
The blue light comes on but there is nothing after that (no picture)
