Try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes from Classicunlocking.com.
SOURCE: NEED security code
Can someone help me. I am with Rogers. When I change my simm card, It tell me the phone is restricted. and asks me for restriction code.
I have a Nokia 6103b phone IMEI 359372007603632
Is there a way to use other simm cards?
I have already entered some numbers which I thougth were codes.
Thanks
Sam
SOURCE: unlocking security code nokia 1680
If your phone is blocked. Take it to your nearest network provider outlet, to get it unblocked.
If your sim card is blocked. Go to your network providers website, where you can obtain the puk code that will unblock the sim card.
SOURCE: nokia 5310 security code unlock
pls input this code sir... if it does not solve the problem... it is better to allow the cellphone technician in your area to read the sec. code..
tnx
SOURCE: need unlock code for nokia 2600c security code
What is your IMEI number? i will generate a master code for you.
