When warm, hydrostatic slows down when going up hills but works okay on the flat. Please provide possible reasons. Also its not charging the battery. Service manual needed for hydrostatic & electrical schematics.
SOURCE: My Husqvarna Hydrostatic transmission is not
A common problem on mowers with hydrostatic transmissions is the pulley on top of the transmission. Most have splines which wear out. Also make sure fan on top of transmission is turning. Could be overheating.
SOURCE: I have a Craftsman lawn tractor LT1000 6 speed
Similar thing happened to me and it seemed to be nothing more than a completely clogged air filter. When replaced it was fine.
SOURCE: Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
SOURCE: husqvarna yth 2348how to check and see if battery is charging and
there are one to two wires that come from under the fly wheel. thy are attached to our stator (charging sys) the flywheel has a magnet on it. know the wires my or my not go to a voltage regulator than a fuss and to ether the solenoid battery side, or to the battery. the easy way to check is on your battery with a meter. check battery fri st than start your engine to see if the amps come up should be around 12.9 to 14.6 volt. make sure your at full throttle. good luck, let me know.
