Battery
SOURCE: do you have to take the entire side cover off of
Yes you do have to take not one, but both sides off: First take off left and right pedals, a 14mm or 9 l16 end wrench will do the job. Then you will find specific holes where the screws that hold the side panels are I think they are # 15 or 20 torque ( star confiuration). This will expose the frame blow all the debris out. Last ,but not least you will locate the battery behind and below the alernator two phillips heads screw hold the 6v @ 2.5ah battery in place,then replace the the battery, and reassemble the unit. This sholud not take more than 30 min to do.
SOURCE: Where can I get an electrical schematic diagram
Click here then click on LC95RS-0109-04 Parts list and the wire schematic is on the last page.
Testimonial: "Thanks. Helps trace the wiring. Now to find the problem and fix it. "
SOURCE: I also have a lifefitness recumbent 9500RHR. The
That component is a capacitor and not a battery, The battery is locate on the back portion of the bike frame, tilt the bike to its side you'll notice a plate remove the 4 screws flip the plate over. On that plate is the battery it has 2 leads red ( + ) and black ( - ) leave them on until you purchase the new battery. After receiving the Battery their is 2 screw that attach the battery to the plate and replace with new battery reverse procedure to install.
You may purchase this item from National Gym Supply Part # LC001.5
cost $19.80 tax and s/h Call them @ 1-800-496-7278
Recumbent bike works best for elderly people with back and hip problems
because of the relaxed position and the angle that put's less pressure on those
areas. Upright exercise bike works on more areas than the recumbent bikes
including the lower abdominal muscles.
