Sony ICD-P320 Digital Voice Recorder Logo
Posted on Nov 08, 2008
ICD P320 digitacl recorder by siny
Download for drivers Vista 64 bit operating system and this product. Cannot use on my new computer
  • 7 more comments
  • jsm04003 Nov 30, 2008
    I also have ICD-P320 and I can't use on new computer either. I'm wondering if it's the Vista.
  • Anonymous Dec 13, 2008
    i also have the same prob
  • Anonymous Dec 26, 2008
    I have the same problem. I cannot believe this!!!!! vista is unbvelievably screwed up
  • nickabodd Jan 01, 2009
    Same problem. Worked great on my old Vista system, but not even a little bit on my 64-bit Vista.
  • Anonymous Jan 13, 2009
    Sony doesn't have a driver for 64 Bit versions of the Vista operating system.
    http://esupport.sony.com/CA/perl/swu-dow...
    Is there somebody who can help me to find one?
  • glking5 Feb 11, 2009
    Same problem. I wish this was the only item that won't work with Vista 64. I guess I will have to go back to XP or Vista 32. What a rip-off!
    G King
  • Anonymous Feb 28, 2009
    same issue
  • Anonymous Mar 05, 2009
    I have the same problem...What can I do?
    I have ICD-P320 and I can't use on new computer either. I'm wondering if it's the Window Vista Home....I don´t know...please help me...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2038
Points
That is NOT the 64 bit vista driver. At least my Vista 64 will not find the ICD-P320. The Digital Voice Editor installs fine, but the driver does no. Even going to the downloaded folder with the drivers and executing the setup for it does not work.
Other ideas, please.
Anonymous
Level 1:
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2038
Points
1helpful
Need to have the drriver for unit Sony ICD-P520
Hello you can find a download on this transcription kit http://www.tvps.com/Products/SONY-FS-85USB-Transcription-Software-Kit---New-FS85USB__SO-FS85-USB.aspx on the bottom of the page is a link for the New SONY Digital Voice Editor 3.3.01 - includes drivers. Before downloading and installing the software, please check the system requirements: to determine whether or not this program is compatible with your computer.
Good Luck.
2helpful
I need a driver in order to be able to use my Sony voice recorder ICD-P520 on Windows 7 64 bit
Unfortunately, Sony does not support this recorder under Win7 64-bit. See http://esupport.sony.com/US/perl/swu-list.pl?mdl=ICDP520&SelectOS=27 for the available drivers. You can try the Vista or WinXP driver with the compatibility mode. (This may involve allowing unsigned drivers since there is no information on 64-bit compatibility on either the Sony or Microsoft Vista Compatibility site.)
To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
My operating system is windows 7, and unable to find a driver to operate my sony ICD-P320 recorder.
Sony does not support Windows 7 for this device (yet?)
However, Windows Vista uses the same driver model, so there is a good chance the Vista drivers and software work for under Windows 7, too. You may have to override some warnings from User Account Control (UAC) during install.
Problems to make the sony icd-sx25 software editor recognize my hardware when i connect to pc with usb cable. using a windows vista home premium 64 bit operating system
There is Sony Digital Voice Editor Version 3.2.01 available to work on Windows Vista Home Premium 64-bit.
Click Sony Support to download "DVESetup_EN_3201" file (size approx 83MB) and install it in your computer, this will solve your problem of ICD-SX25
Thanks.
2helpful
I need to down load the driver for icd-p320
You can download free driver from http://esupport.sony.com/CA/perl/swu-list.pl?mdl=ICDP320&SelectOS=7#div_pos_110
Just select your operating system type first..
Regards,
Jeep Brainy
9helpful
4answers
8helpful
2answers
ICD-P520 driver for 64-bit operating system
the only way to use this on 64 bit systems is if you can suck your own pen1s. once this is accomplished, please send photos proving this act to sony and they will release the 64 bit drivers
Mar 12, 2009 • GPS
3helpful
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
