When at stoplight I push gas pedal to go and motor acts like it's getting to much fuel and bogs down allmost stalls, when I let up on gas pedal and give it just a little gas it slowly increase rpm and suddenly is ok and can take full gas pedal.
The fuel pump relay will cause a stalling or no start condition. You are likely having mass airflow sensor, fuel pump, or fuel pressure regulator issues.
Bret
RepairPal.com
same problem here with my 740 .. it will drive fine to around and below 2k rpm but if I try and accelerate to past 2k rpm the car stumbles then I may turn it off for a few hours or minutes and everything is fine ??
I am trying to replace the fuel pump relay this week to see if that could be the issue..
i have 2001 cavaliar when giving gas the engine acts like it is starving for fuel and also the rpm gauge when giving gas goes up and down
