Need to replace the pump drain on a Top Load Stack washer/dryer combo. The back is an all metal panel that is tacked into place and cant get it off. Any ideas as to how to get to the pump drain to replace? The P/n is 131661700 on the installation booklet. HELP!!!!
Doug
Thank you for your post, friend!
From the information you have provided your Frigidaire laundry center is leaking water from the bottom after a day or so. It sounds like you have a slow leak and this could be in your drain line, drain pump, or gasket. I would advise you to review your gasket and drain hose to make sure there is no visible crack or wear that water could be leaking out of. If you do not see any apparent leaks it could be an issue internally and this is not a simply DIY job. You may need to request the assistance of a professional technician for proper disassembly of your laundry center. I hope this information has been helpful. -Matt
Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
