I have an Amana model no. ARB2214CB with a bottom drawer freezer. My problems started when the seal on the pull-out freezer door was loose at the bottom and went un-noticed. The freezer and fridge went into defrost and I heard a loud buzzing and clicking. The frequency increased, and I reqalized that the freezer was starting to defrost. I removed everything from the fridge and freezer and unplugged the unit. I put the seal back into place, and the unit sat overnight. I plugged it back in, in the morning. ...It was ok for a day and then the noise started again. I have cleaned and vaccuumed everything and pulled the panel off the back of the fridge. The condensor is very noisy and started loud buzzing again, which progressively gets louder, and then 'clicks' off. I have unplugged the fridge again for a few hours and then plugged back in. ...seemed to be ok for a few days, and then buzzing started again. As day goes on, buzzing becomes more frequent and louder. The condensor feels extremely hot. ...also checked behind the back panel inside the freezer and there is no ice build-up. I called a local Amana dealer and they can't trouble shoot over the phone. Can you help?
If there's an ice maker but you don't have water piped to it therefore and it can't work, try pulling the wire arm up that turns off the ice maker. It's down in the freezer, on the upper left freezer area.
I replaced my capacitor on my compressor before I noticed this. It's easy to drag something by it and bump it down.
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
SOURCE: I have a three year
This could be a double problem.
Yes the auto defrost cycle seems to have failed allowing an ice build up.
Secondly the door seal is leaking allowing warm moist air to sneak in. You probably need a door gasket too.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
