Garmin nuvi 255W GPS Receiver Logo
Anonymous Posted on Sep 05, 2017
Having problems with my Garmin nuvi 255w, it won't work for me to touch anything.
The screen comes on, but it won't let me select anything by touching. From the first screen where it comes up with the Agree button and then when I can enter in either the map or address. Didn't know if there was a way to reset or how to get it to work. Have had this problem before but it usually started working after a few mintues this has been days now.
  • Anonymous Mar 28, 2012
    I have held the start button for like 15 sec. get to the screen where you can recalibrate it. You could hit that screen all night long while pressing the dot. That works but it does not stop unless I turn it off??? I have tried pressing the right side of the lower level while turning it on and I am not getting any pop up boxes at all.
    It had worked fine for me on saturday afternoon and then went to use it saturday evening and could not get it to work to type anything in.
5 Related Answers
Anonymous
  • 174 Answers
  • Posted on Jul 23, 2008
SOURCE: Garmin Nuvi 350 Touch Screen unresponsive
try updating the firmware...
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
I don't think you need a password for that...
Anonymous
  • 23 Answers
  • Posted on Jun 12, 2009
SOURCE: Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
Anonymous
  • 1111 Answers
  • Posted on Jul 01, 2010
SOURCE: I have a Garmin Nuvi 255W and the screen will not work
it could be your digitizer or it could be locked up...try turning it on, then hold the slide switch to turn it off for about 15 seconds, then power it back on...if that fails, with the unit off, press and hold the lower right corner of the screen and then slide the power switch toward the on position and you should see a screen asking if you want to erase all personal data (note: this will erase al your favorites) let go of screen and select yes and follow on screen instructions...
if none of those solutions work, download the web updater and see if you have the latest updates.
Garmin Web Updater HERE
if all the above fail..i would say you need a digitizer ...there about 20-30 on ebay
let me know if you need further help
bill
EX 9d25cbc.gif by Choice
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Mar 28, 2011
SOURCE: touch screen is frozen on Garmin Nuvi 255. Once it
Touchscreen needs replaced. Please see this link. There is too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Anonymous
  • 343 Answers
  • Posted on May 29, 2011
SOURCE: my garmin nuvi 255w keeps
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
2answers
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
1helpful
Touch screen doesn't work
Have you tried the screen recalibration; by touching the upper right of the screen for 30 seconds or so while turning on the unit. This usually cures the problem.
Next try; sliding the "Power" key to the left position and hold it for eight to ten seconds to reset the Garmin. I have attached a link to the Garmin manuals for your 255W.
Once you get it going you should update your unit also at the Garmin site. The updates will fix the software glitches.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00718-20
My gps Garmin nuvi 255W touch screen is broke, how can i fix it??? is it expensive ???
My GPS Garmin Nuvi 255 touch screen is not responding. How can I fix it?
How do I change the country on my Garmin nuvi 255W?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Stuff happens. Try this:
This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  3. Touch the down arrow
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  7. Touch American English
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
7helpful
My touch screen is not working
Have you tried starting from scratch.Go to Tools then
Settings then Display,make sure the Screen Shot is Enabled,hope this works for you.
2helpful
The screen background color
This is night view. Go to page 34 of the manual and select Customize section Set your Nuvi to auto from TOUCH TOOLS SETTINGS
My Garmin nuvi 255W will not go off of the garmin screen....any suggestions
You can try plugging it into a computer via usb cable and see if that snaps it out of it other wise try doing a hard reset, you will loose all data but its the only option you seem to have. Hold the bottom right corner of the touch screen and power the unit on. wait until you see the confirm delete and select yes.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
