Not a lawn boy.drive belt has slipped off.need to put it back on and adjust it.mower is only 1yr old.21 inch commercial toro.not lawnboy.mower is red with honda motor.how do you access the rear drive unit.
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
SOURCE: My Self-propelled push lawn mower
try putting new bail one it and see what that dose 9 out of 10 that's what is
SOURCE: I HAVE A TORO SP
It sounds like the cable still needs more adjustment. The cable needs to be tighter. This is going to be hard to explain by typing. But I will give it a try. When you pull the handle in about 1/2 way mark the place where the lever on the drive motor is at. And take the cable loose and reattach the cable back to the mark that you made previously. So when the bar is released, it is like it is pulled in half way now. I hope that this makes sense. Let me know if I need to try to explain more.
