Where cmos battery located on my compaq presario sr1350nx
SOURCE: REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
SOURCE: compaq presario SR1350NX problem
Looks like you have a boot sector virus. Go here and download an antivirus for boot sector:
Avira AntiVir Bootsektor-Repairtool
If that does not resolve the issue, Try going into Safe Mode and see if you can get into Windows. If you can, then it could be that one of the drivers is conflicting with another and you may have to rei.nstall the drivers
SOURCE: My computer clock is running fast... I figure it's
just u will remove the Cmos battery from your computers mother board and take it.
go to shop and ask like this battery i need.
then buy and replace it..
thank u sir... All The Best...
SOURCE: I have a compaq Presario
Does it loose time even with power cable connected? If so I would say your MB has a bad RTC chip and you need to replace the motherboard. Other things to check are make sure the CMOS battery your using is BRAND NEW with a good expiration date. That the contacts on the MB are making firm contact with the battery. Also check to make sure the contacts are CLEAN... no residue on them.
