How do we replace the fresnel and lenticular screens on our 60 inch Mitsubishi tv?
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Is ther any question I did not answer for you? Just wondering why you rated this as helpful, I thought I had answered all of your questions
it gave me good general knowledge about screen replacement. Something hit the bottom of my 73" Mitzubishi lcd last night. a dark spot developed at the bottom left of the screen and is moving upward and to the left fairly steady. Any suggestions?
