I have a Compaq using Windows 7 and att 2wire . I have 2 other Laptops and 2 xboxs as well as phone working off the 2wire so I know it is working . My Compaq did work then stopped I get a Access points problem/ Reset Modem which I have . I dont know what a access point it or how to CHECK It or Change it Any info wold be appreciated Thanks
Users don't be able to know that how to change wifi password of the ATT router & looking for the instant solution online from the expert's end need to contact @18885855194 toll-free number & fixed all the issues related to ATT router.
Unable to connect to Internet - Error Codes (13), (22) and 86-844
I have a problem connecting to the Internet. My DirecTV equipment is as follows:
Receiver: DirecTV HDDVR (Model: HR22/100)
Ethernet Wireless Bridge: Linksys WET54G ver. 3.1
Router: Linksys e3000
- NB: this currently provides home network support for about 8 other devices (all working ok)
1) DEFAULT Option
When attempting to connect to the network with default settings I receive the following error:
IP Address: 169.254.9.168 ok
Subnet mask: 255.255.0.0 ok
Default gateway: - -
DNS: - -
Network: Connected
Internet: Not Connected (13)
Result Code: 86-844
2) MANUAL Option
Because the default option failed, I also tried manual settings to specify a static IP address, subnet mask, default gateway, and DNS. I then got the following error:
IP Address: 192.168.1.65 ok
Subnet mask: 255.255.255.0 ok
Default gateway: 192.168.1.1 ok
DNS: 205.152.37.23 ok
Network: Connected
Internet: Not Connected (22)
Result Code: 86-844
I also used the RED RESET button on the DirecTV receiver as suggested in an earlier post but neither approach worked.
URL: https://www.buzzmeweb.com/how-to-change-wifi-password-att
Use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
SOURCE: Laptop can't find access point!
Some laptops come with a button\switch or use key combination to turn on or off the wireless(to conserve power)! Refer to your user manual for exact instructions! If that didn't solve the situation then it could be your actual wireless card within the laptop is giving trouble! regards, babb
SOURCE: Repeater
The repeater must be the same brand as the signal it is repeating. Different routers / access points work in slightly different ways and the current generation of wireless repeaters aren't smart enough to work with other brands.
It's kind of like trying to put an engine from a Nissan Altima into a Honda Accord... both make the car move but they aren't the same inside.
SOURCE: The 21ooap acess point confoguration
I think that you trying implement NAT on this wireless access point , if you got /24 mean you can use 192.168.16.1 - 192.168.16.254 range.This kind of router do have few steps to go basically you have to provide WAN settings that your up link information, then your Broadcast information such as SSID,DHCP,WEP.WPA,etc.
SOURCE: Access Point AP2750 Problem
i would try updating the firmware on your router and access point. I had the same problem and did this to both and they are now working fine. Let me know how it goes.
SOURCE: After a windy day lost wireless connection
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc. then in network connections setup your lan port TCP/IP settings as follows. ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config. instructions on the engeniustech.com support page.
The Wireless Light is ON the Compaq Also , If I plug in thru the Ethernet cord it works ???????????
