I have removed all the parts except this one. This piece has failed and we are no longer to open the door without damage. This one piece needs replacement, but cannot get part loose, seems wedged in the door. Is there a release that I do not know about?
SOURCE: 1999 Ford F150 supercab - back driver door won't open
Latch —Rear Door, Lower
Removal
SOURCE: hyundai accent '02 inside door handle & Lock removal
Removing the door is very tricky, trust me on this. I ended up breaking it the first time, so please learn from my mistake.
1. Remove all visible screws: 2 at bottom of door, 3 on front near
hinge, 1 on inside the door lever. You will need an average size
phillips screwdriver to do this.
2. On the door handle itself, you will see two circles. Pop the front
one out. You will need a LARGE size phillips screwdriver to do this.
3. Once screws are removed, take a (standard) flat-head screwdriver,
preferable one with a large face, and pry the triangular piece of
plastic (that covers the outside SIDE mirror) off. This will aide in
puting the door panel back on...TRUST ME!!!
4. Take the same flat-head screwdriver, and pry behind the door lock
(at the same time, push forward toward the door hinge). The assembly
should pop out.
5. Gently pry the door panel from the door, making sure not to break
any unnecessary pieces along the way. The door panel should be hanging
by the window sill opening.
6. This is where it will get tricky. It is advised that you use help
with this part: Angle the door panel at a 45 degree angle. AT THE SAME
TIME, slightly bend and twist the door lock handle until it fits
through the hole. You will see the 3 pegs the held it in the door from
before. Also note: Be careful not to break the 2 poles that are
attached to the lock.
7. After popping the lock through the hole, you should be able to lift
the door upward, and off the sill. Repeat these steps in reverse order
to re-attach door panel.
Be careful not to rip sound-deadening paper found on inside of door
unless you intend to remove or replace it! Not only does it prevent
dirt and moisture from entering your door (and possible rusting it from
the inside out), but it makes your speakers sound better too!
-SportTunerFreak
**It is also recommended to put a tiny bead of silicone on the inside
of the door panel to help suppress any rattling, and prevent moisture
and dust from entering. It also helps your screws obtain a tighter fit.
Hope this helps!
SOURCE: Jeep TJ Wrangler Outer door handle removal
The handle is held in place by two vertical wedges on both sides of the handle. To remove just force the wedges up with a hammer and screwdriver (be careful of the glass). Putting them back in is very difficult. I would suggest making the bends or adjustments with it installed so you'll know exactly how much you need. I hope this helps.
SOURCE: Removal of 1998 toyota cressida ignition key cylinder.
This car has drillable shear pin screws on the bottom of the lock yoke you must drill these out.
then release the clip to the cylinder. you must get a new set of break-off shear pin head screws from the dealer to finish the job.
SOURCE: Removing manual window handle at door panel
Uses a "c" clip to secure window handle. Requires a special clip removal tool, that can be purchased at the parts store. Hope this helps
