SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
SOURCE: konika minolta
CDC## Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
SOURCE: Konica Minolta Bizhub c350 error code c-0510
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
