Question about Samsung SWA-4000
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
Hi! I have a Samsung HT-TZ315R home theater system and I am trying to connect the two surround speakers with the main unit using the Samsung SWA-4000 WIRELESS TRANSMITτER MODULE but it doesn't work. I followed the manual step by step pressing the buttons "0", "1", "3", "5" on the remote control and kept pressing the "SET ID" button for 5 seconds on the wireless module so that the main unit and the wireless module can sync but it doesn't work. Can you please help me out?
  • 4 more comments
  • Shawn Johnson Jan 09, 2009
    I have a HT-TWZ412T. My SWA-4000 connects with the main unit, but still does not deliver sound to the speakers. I have changes swapped speakers, but still no sound. Can anyone help?
  • dwaj12096827 Jan 12, 2009
    I have the Samsung swa 4000 as wel, My Link light is a ateady blue, but I still get no sound from rear speakers. We tries the 0,1,3,5 and the ID Rest, with no luck. Any other helpful hints?
  • Anonymous Feb 24, 2009
    I do not understand why my wireless module will not connect to the main receiver unit. I have tried pressing 0135 on the remote while the power is turned off the main unit while the wireless module is on standby. after entering 0135, I immediately hold down the id set button for 5 seconds and release. Immediately after the 5 seconds passes, I turned the power on the main unit, and it does not connect, it only blinks blue until it eventually goes to standby again. please help as this can be very frustrating after spending lots of money on this system
  • lucampere Feb 28, 2009
    I have the same problem. I just bought a SAMSUNG HT-X715 and a SWA-4000 but the wireless connection does not work. The blue link fails all the time. I have made as indicated by the user manual but nothing ;-( thanks for the helps ;-)
  • mariobros Apr 11, 2009
    Hi, I have a Samsung HT-TZ515 and I can't program my SWA-4000 to my system. I follow the steps by pressing 0,1,3,5, on the remote and by pressing the SET ID button on the module for 5 seconds and I can't get it to work.Can anyone help? Thanks.
  • Mohammed Lamhamdi
    Mohammed Lamhamdi Feb 21, 2019
    i have problem with tx card is cased
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
    Problem Solver:
  • 5 Answers
You have to plug the 2 spair speaker cables into the 2 rear speaker ports on the reciever. The wirless speaker setup should work than... I had the same problem until I plugged them in.
Posted on Aug 19, 2009
    New Friend:
Mine was doing the same thing. My simple solution was to turn the wireless card over. It fits in my samsung both ways and I had it upside down...duh. turned it right side up and everything checked perfectly. :)
Posted on Dec 31, 2009
    New Friend:
Does the swa-4000 come with the tx card?
Posted on Jan 13, 2010
Make sure you have the wires hooked up to the 2 back speakers and then stick the wireless moduel near the 2 speakers in the back. The blue light on the moduel should stay a steady blue.
Posted on Mar 12, 2009
Hi guys, I have soved my problem with the SWA-4000. Well, at the first time, after I have performed some tests with my Home (HT-X715) and the SWA-4000, I took them to the store where I have bought them. So they give me another one (both systems were with problem!!!!!). I should help you!
SOURCE:
My SWA-5000 is not connecting to my main unit, which is a samsung blu-ray home theater system. I have already tried what it has said on the manual, but it still wont turn on, it is just on standby. Please...
start with the main unit turned off. Press and hold the button on the back of the swa-5000 module until the light on front starts blinking fast. Then point the remote at the main unit and press 0-1-3-5-ENTER. The standby light on the main unit should turn off then back on. Turn on the main unit and it should find and link with the wireless amp.
Dec 20, 2014 | Samsung Wireless Amplifier Swa-5000 For...
Will a swa 5000 tx card fit a ht-tz225 home theater ststem
Unfortunately it would appear not. I just bought an SWA 5000 for my HT TZ 225 home threatre system as it would seem the SWA 4000 has been discontinued - the HT-TZ225 refers to the SWA 4000 doesn't it.
The tx card that accompanied the SWA 5000 was too big and did not fit in the back of the DVD player so I will have to return this to the retailer and keep looking for an SWA 4000 . . .
Unless anyone has another solution.
Apr 28, 2010 | Samsung Audio Players & Recorders
I'm having problems getting my swa-4000 system to work tried the code and holding down the reset button i have an ht-x715t system and the tx card is in right any idea's thanks
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jul 03, 2009 | Samsung SWA-4000
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
SWA-4000 Sound Interference Problem
i also have this problem not when watching dvds but when watching cable tv. would like to no what the problem is
Feb 23, 2009 | Samsung SWA-4000
Speakers won't connect
Here is a link to Samsung's HT-Z510 Home Theater rear speaker troubleshooting guide.
http://www.samsung.com/us/support/popup/howToGuidePopup.do?howto_guide_seq=629&type=hometheater&subtype=hometheatersystems
It has worked for me after a couple tries. Good Luck!
Dec 27, 2008 | Samsung SWA-4000
Wireless speakers
Google "Samsung SWA-4000" The HTz310 is wireless "ready" only. You'll need to purchase this unit for about $100 to make your (Rears only) wireless.
Dec 07, 2008 | Samsung HT-Z310T Theater System
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
Samsung SWA-4000 Logo
18,765 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
