Coby Kyros 716829701508 Tablet PC Logo
Posted on Jul 13, 2017
My screen on my Coby Kyros MID7125 is reading backward
I have a Coby Kyros MID7125 and everything on my screen suddenly turned backward, all the writing and pictures and such, how do I fix this, I have tried turning it off and on and pushing the reset button and nothing has gotten it to turn back the right way, it did the same thing last night but then realigned itself after a short time, but it has stayed that way now, and the screen isn't steady either, it flashes too
2 Related Answers
iiiears
  • 14 Answers
  • Posted on Apr 08, 2011
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Anonymous
  • Posted on Jul 23, 2011
SOURCE: my coby kyros won't turn
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
Cant remember my password
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
Hope this Youtube tutorial might help you:
Factory reset on Kyros MID 7012 without using Settings
Also you should read these tutorial:
Coby Kyros MID7010 hard reset
http://webcache.googleusercontent.com/search?q=cache:eQiuI75ELTMJ:resetandroid.com/coby-kyros/+&cd=6&hl=es&ct=clnk
http://www.androidtablets.net/threads/how-to-factory-reset-on-coby-kyros.24344
You can get some more information doing a google search for
factory reset of Coby kyros Tablet
UNFORTUNATELY I WAS **** ENOUGH TO PURCHASE A COBY KYROS. LESS THAN A YEAR AGO AND NOW ALL THE SUDDEN IT WON'T TURN ON IT WON'T LIGHT UP IT WON'T DO ANYTHING. IS THERE AN EXPLA
check the on off switch and the battery, if its something other than this it will have to go to a repair center . which more than likely will cost as much as a new tablet.
My coby kyros mid7125 is froze on the coby screen how do I unfreeze it
Hold down the the power button for 30 seconds and wait for the tablet to power down. Now turn it on. This is the first thing to try.
There is a tiny reset hole in the side of the tablet you should be able to get a reset out of.
Sometimes, the battery must drain all the way and then the table recharged.
Have you rooted this tablet or used CW recovery on it? Or is this a stock tablet?
How do I factory reset my Coby Kyros 1125?
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
32helpful
4answers
Screen is frozen will not turn off or go back to main menue
im having the same problem no solution.when i try to turn it on it just freezes on coby.HELP FAST PLEASE!
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
