SOURCE: how to open front camera in w910i sony ericsson mobile
front camera is used for only video calls but u can still record your video msg by using your front camera.
you need to to go in video call option in menu and than press for any video call but a msg will apear into your phone's screen that video call failed.
now is there will be an option that you can send you video msg with your front camera..thats it
From Vikram Kanojiya
New Delhi-110055
SOURCE: unlock my sony ericsson w910i
There is no free code generator for the W910i. You would need to contact the original network operator for an unlock code (they may charge).
You could try unlocking the phone yourself using the guide here.
SOURCE: i want to unlock my sony ericsson w910i fre how
hi friend,
press * and then press the right soft button to unlock
if it doesn't works check this out
Unlocking your Sony ERICSSON W910i is just the start of roaming freedom. This safe, simple process is one of the easiest ways you'll ever find to save money. The unlocking code and five minutes of your time will enable you to use your handset in ways you never thought possible.
We need only a short time (no more than 12 - 24 hours ) to generate your Sony ERICSSON W910i subsidy code. The sooner you place your order, the quicker you'll receive the unlocking code and be on your way. Both ordering and entering the code are easy. Just follow the instructions.
How It Works
Once you have received your Sony ERICSSON W910i unlocking code, it is very simple to enter it:
hope this helps u
ERICSSON-W910i-,K850i-&-W890i-UNLOCK_...%20-">cgi.ebay.co.uk/UNLOCKING-FOR-SONY-ERICSSON-W910i-,K850i-&-W890i-UNLOCK_... -
thank u for using fixya
please rate me............................
regards
sivaranjini
SOURCE: How do i format Sony Ericsson W910i
My phone have problems :
1. when i try to open games or application list from desktop, the phone display "operation failed"
2.the
Walkman icon on desktop cannot be executed , same with the Walkman
button ( when i press the button or icon , nothing happen)
3.the "operation failed" msg are also diplay when im trying to run SensMe function
Can
i do the formating on my own computer? how to do it? will it fix the
current problem? or is there any other method i can use without
formatting?
PLEASE HELP ME..Thank YOu!
