Push trigger the air start to blow.then then fault light starts to flash.check pwr.ground, air, put new tip an elerco, in torch.it still flashs fault.
SOURCE: It does not work it just flashes the fault bulb
when mine act like that I check the tip make sure the air pressure is right and that it has a good ground
