SOURCE: Printer driver for Canon MP610 to work with Windows 98 please?
there are no drivers available Windows 98 or Windows Me,this operating system may not require a driver or in this case of older operating systems may no longer be supported. try upgrading your windows,THERE ARE DRIVERS FOR WINDOWS 2000, XP,VISTA. SORRY FOR THE BAD NEWS
SOURCE: default settings canon pixma mx700
If you are using windows, you would go to your start menu. Then select control panel. In the control panel, select the printers icon. Right click the MX700 icon and select printer preferences. This will now allow you to change the default settings.
SOURCE: Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
SOURCE: MP610 BLACK PROBLEMS
When that happens the purge assembly is not working right. Sounds like the tube for black cleaning and priming has come off.
