I have this Culligan 5 gal. water cooling stand that take a 5 gal jug of water. I am looking how to adjust the temperature of the water. Model: BCG1SRK Serial - 9919211064. I have no manuel with this cooler as a friend of mine gave it to me and they no longer need it and so I took it but no manuel was provide even to them. I would like a manuel.
SOURCE: my cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
SOURCE: my wine cooler no longer cools the temperature is hot
Do you hear it running? Usually there are two things that happen with wine coolers when they get warm. The first is a faulty cold temperature control, failing to turn the unit on despite our attempt. You should have one, possibly two or more fans. If you have any, and they do not run no matter where you set control, that is likely your problem. If you dont have any fans - you will likely have a black plate with some "bubbles" around the back and side walls, Then you may have to have a service company test your compressor, to see if the compressor itself or the starter has failed.
Assuming the other motors on the cabinet are running, you've narrowed
your problem down to 2 things, the compressor itself, or the start
device has failed. Without the proper tools you wont be able to test the
compressor first. My advice, go to repair clinic . com, see what a
starter will cost you, if you can find a repairman to check your
compressor for cheaper than what it costs to buy starter, well there you
go. Either way, if its the compressor thats bad, you wont want to spend
the money to replace, unless you have a built in worth several
thousand, or physical constraints of kitchen prevent you from buying new
fridge.
Visit: www.FixMyFridge.net for
Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
SOURCE: GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
SOURCE: Cannot get temperature below 65F. Probably
I have never heard of a wine cabinet getting below that range? Has this unit every reach temps that low before? I would make sure the unit is breathing, check the condenser and air flow through the unit. If the unit is not choking, and temps can go below 65, than yes you will need to have it serviced. It can be a thermostat issue.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: i have a pioneer table top water cooler model
Mine stopped cooling too!!! It is only about 6 months old....
