1995 Cadillac DeVille Logo
Posted on Mar 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any stereo wiring diagrams or codes online
ZJ Limited
Level 3:
  • Cadillac Master 17,989 Answers
  • Posted on Mar 27, 2012
ZJ Limited
Cadillac Master
Level 3:
Answers
17989
Questions
0
Helped
14457988
Points
60858
Check this for 1995 Cadillac Deville Car Stereo Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: OrangeCar Radio Accessory Switched 12v+ Wire: YellowCar Radio Ground Wire: BlackCar Radio Illumination Wire: GrayCar Stereo Dimmer Wire: BrownCar Stereo Antenna Trigger Wire: PinkCar Stereo Amp Trigger Wire: N/ACar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: 5 1/4" SpeakersCar Audio Front Speakers Location: DoorsLeft Front Speaker Positive Wire (+): TanLeft Front Speaker Negative Wire (-): GrayRight Front Speaker Positive Wire (+): Light GreenRight Front Speaker Negative Wire (-): Dark GreenCar Audio Rear Speakers Size: 6" x 9" SpeakersCar Audio Rear Speakers Location: Rear DeckLeft Rear Speaker Positive Wire (+): BrownLeft Rear Speaker Negative Wire (-): YellowRight Rear Speaker Positive Wire (+): Dark BlueRight Rear Speaker Negative Wire (-): Light Blue
Hope this helps.
1982 Oldsmobile Delta 88 Royale. The radio is missing and the connector going into the radio has been cut. I need to know where or what the color coded wire are coming from like the speaker or what?
Question edited for clarity.
Question moved to model category.
Your Question posted as an answer to another Post, deleted.
1984-85 Oldsmobile Delta 88 Stereo Wiring - The 12 Volt
the12volt.com https://www.the12volt.com > installbay > stereodetail
1984-85 Oldsmobile Delta 88 car stereo wire colors, functions, and locations.
Missing: 1982 ‎' Show results with: 1982
Oldsmobile Wire Diagrams and Wire Codes
Car Stereo Removal https://www.carstereoremoval.com > htm > WireCodes...
With aftermarket stereo installation? GM Wire Harness Diagram, Wire Color Codes and Pin Configuration, Wire color codes and wire diagrams.
Wiring diagram to replace radio in a 1990 delta 88?
Fixya https://www.fixya.com > Forum > Cars & Trucks
Apr 9, 2009 - Wiring diagram to replace radio in a 1990 delta 88? - Cars & Trucks question.
1986 Oldsmobile Delta 88 Car Stereo Wiring Guide
modifiedlife https://www.modifiedlife.com > 1986-oldsmobile-delt...
Our automotive wiring diagrams allow you to enjoy your new mobile electronics rather than spend countless hours trying to figure out which wires goes to which ...
2003 Ford Escort ZX2 stereo wiring diagram please?
2003 Ford Escort ZX2 Audio Wiring Chart
MODIFIEDLIFE https://www.modifiedlife.com > 2003-ford-escort-zx2-...
Our 2003 Ford Escort ZX2 radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 Ford Escort ZX2 Radio Wiring Diagram ...
2000 Ford Escort ZX2 Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
2000 Ford Escort ZX2 Stereo Wiring ; Antenna Trigger, n/a ; Antenna, Right Rear ; Front Speakers, 5 1/4" Doors ; Left Front (+), Purple ; Left Front (-), Blue/Orange.
Ford Escort Stereo Wiring Diagram
Pro Street Online https://my.prostreetonline.com > 2016/03/10 > ford-es...
Mar 10, 2016 - The Ford Escort was available through three generations, and today I'll be showing you our Escort stereo wiring schematic from 1980-2003.
4helpful
3answers
Trying to match my aftermarket radio with factory speaker wires.. BROWN YELLOW GREEN VIOLET / WHITE STRIPE LT BLUE LT BLUE / BLACK STRIPE WHITE /RED STRIPE WHITE / RED STRIPE
Greg, Check the attached links,instruction and guides stereo and speaker wiring, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WIRE COLOR CODES FOR CAR INSTALLATION
Car Stereo Wiring Diagrams and Car Radio Wiring Diagrams
https://www.installdr.com/quickwiring.asp
Car Stereo Wiring Diagrams Director
Color coded stereo wire diagram for a 1996 Honda Civic LX would be greatly appreciated ASAP!
My county library system puts Chilton manuals online, with wiring diagrams, perhaps yours does too.
I need a car stereo color coded wiring guide mitsubishi galant ES
They are very easy to find online. Just google wiring diagram for the make and model.
1helpful
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
24helpful
2answers
Need stereo wiring diagram
1998 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amplifier Location: Behind the glove box.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
4helpful
2answers
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
