TV is Samsung PN43D450A2D and it turned off the other day and now wont turn on checked the power board no bad cap. and looking to see if anyone out there had any thoughts.
If caps there not puffed or leaking voltages in and out of the power board must be checked next (right at turn on of the set) to see which come up and or instantly go off....this is the place to begin.
Testimonial: "Quick response thanks What could it be if its not the power board? The logic boards wouldnt do that would they "
The main or the board with the micro on it could or any board holding a voltage in the power supply down---even seen some where it ended up being the panel..............
I am in the same situation with the exact model pn43d450 tv.
I looked on the internet and i tried to do my best.
1: change the source board-nothing happened
2:change the logic board -nothing happened
So now i think this TV belongs to the dumpster now along with that annoying clicking sound and Samsung will have one client less.(tv was 3 months old but because i was using it in the Bahamas ..no service:))
I did the same even replaced all the boards still doesn't come on so yeah not gonna buy a samsung ever again mine went out after 6 months I bought a new vizio and parted out the samsung
SOURCE: My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
SOURCE: Samsung Power Supply Board
The power supply part number is BN44-00159A. You can also download the info from this link. It's the service manual.
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
SOURCE: SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Testimonial: "I was extremely grateful to have a response in such a short amount of time, as soon as I replace the part that was suggested as bad to me, Ill post."
SOURCE: my samsung plasma tv went out and it just makes a
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
