My fridge is leaking water from front right hand side (as you look at it) - can feel small 'hole' underneath where water is dripping from but cant tell what I need to do to stop it? Would it be my defrost pipe inside (by salad boxes), or pipe at back? Only knew it was leaking as my laminate floor has lifted and buckled!
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
water is slowly dripping from the back right corner and sometimes the front left corner of the bottom of the fridge. We have a kenmore from 2004. The condesation tray is not removable to check it (in case of overflow). Nothing else on the bottom looks wet. Water is only between the bittom of the fridge and the metel piece that's there on the very far back edge. Thanks!
gas leak from outside of fridge door
Small leak from underneath only noticed it because of oak floor damage
