Wiring diagrams can be found here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
SOURCE: My boys have not rode
The battery went bad inside the bike. I would take it out and go to batterys plus and they will help you pick out a new one
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
SOURCE: how do i change the rear tier of my razor mx350?
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
the button fell off it has the negative and positive post like when you putting a battery in something i dont know which way to put them back in the end of the red on off switch has springs on the end
