Televison & Video Logo
Posted on Nov 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color convergence still busted
Swapped out the STK's and upon testing there was no change. But I found a burnt resistor. I suppose I should have looked harder the first time. Anyways, it's discolored so I can't tell its value. Its PCB id# is RK62.
Can you please tell me what its value is? Is this a symptom of another problem? Any and all input is greatly appreciated.
thnx Robert in AZ
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Nov 11, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783247
Points
6681
2.2 ohms/1 watt if you have chassis number AP74.
3.3 ohms/1 watt if yo uhave chassis number AP73.
1helpful
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
The color is out on my tv
U mean all ur colors picture lines on the tv are misaligns?Ur tv convergence are dead.This problems are the 2 STK convergence ICS and some or all it resistors are dead.The convergence board the 2 STK Convergence ICS and those resistors must be change to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
3helpful
2answers
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops...
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
2helpful
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Zenith R60v26 has burnt resistor at RK5 on convergence board
Hello, I have the exact same issue with my R49W36, I replaced the convergence chips but there are also two 1 ohm resistors with the same color pattern as yours that are bad. I have looked all over and cannot find a 1 ohm resistor anywhere. Where did you find it?
3helpful
2answers
Too much red!
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
3answers
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
2answers
PT-53WX52
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
2answers
Convergence problem
replace the stk-392-110 (x2) and any burnt resistors. cost 20$
2helpful
2answers
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
