Computers & Internet Logo
Anonymous Posted on Mar 26, 2012
Restaurant Pro....is there anyway to delete a modifier without deleting the whole order on the invoice? I.E. Customer orders a salad, changes their mind and does not want tomatoes. How do I delete tomatoes without deleting the salad?
Anonymous
Level 2:
Sergeant:
  • Expert 213 Answers
  • Posted on Mar 27, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
213
Questions
Helped
79372
Points
516
2 Related Answers
Butch Mattern
  • 310 Answers
  • Posted on Sep 24, 2010
SOURCE: RESTAURANT PRO EXPRESS WON'T LET
It sounds like your having a problem with your SQL server and may need to reload it. Backup your database first just to be safe.
If this is Nicole, I replied to your email about a contact number, but got no response.
B Mattern
[email protected]
Butch Mattern
  • 310 Answers
  • Posted on Sep 21, 2011
SOURCE: We use PC America Restaurant Pro Express at our
The server may have had your admin password. The default password is common knowledge by searching the web. This should be changed or disabled. The information you need is in the database. It will even give you the server ID that deleted the transaction. Someone familiar with querying an SQL database is what you need. I can help you, but not for free. Too much time and experience needed.
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Testimonial: "Thank you, very helpful"
In Restaurant Pro how do I change settings so that each item will appear on a separate line? ie....someone orders a greek salad with a modifier, on same tab another greek salad with no modifiers. The
Hi Judy,
You probably have it set to combine lines on invoices. Go to your options screen. Select SETUP, then SETUP SCREEN. Click the INVOICE SETTINGS tab, then uncheck COMBINE LINES, click UPDATE, then EXIT. Now each item should display on its own line.
If you need further assistance or tech support at reasonable rate, send me line at [email protected]
1helpful
How do I remove a single modifier item from check?
Hi Cafe Eleven,
Ii have worked on this software quite a while and am not aware of any way to delete a modifier by itself. Sorry.
[email protected]
How do i clear my database of invoices, transactions which are closed
Search under "caches" on your system.It should show you all the files in your database.Then right click on the file you want to delete then delete it.
1helpful
We use PC America Restaurant Pro Express at our restaurant. I had a server delete invoices before they were closed out (but after the customer had paid her cash). I was able to find this out by matching...
[email protected]
I got an order stuck on my screen in pc america and it won't delete, it keeps freezing the computer when you try to fix it, how do i delete it?
Have you tried voiding the invoice? If this also freezes the program, then you will need someone to delete the invoice manually from the database. This is usually done with an SQL management software program. CAUTION: always backup your database before attempting this.
B Mattern
[email protected]
2answers
I have cre Database 12.0031 Product Version: 12.0.0.0 Windows xp I am trying to delete information for "cash customer" under Manager > Customer Maintenance > Customer #101 Cash Customer. Can you...
Open table usually means you have an invoice on hold. Check your on hold invoices and clear that up.
Are you trying to delete the #101 Cash Customer. The system should not allow you to do that and might be causing a conflict when you try to run the report.
Want to buy restaurant express pro is it any good
For the price, it is a good product. It uses an SQL database and can be customized in many ways. As with any good restaurant POS, the main concern is getting the menu programmed into the software so that invoicing flows smoothly. Once programmed, it is easy to show employees how to operate.
Unless you are going to spend a lot of time learning the software, I would recommend letting someone program menu for you. Then you just learn how to modify or change it. (add items or price change)
Here is one reputable programmer's website if interested: http://cpcpos.com/posconfig.htm
Deleting recalled invoices
Hi heafra,
go to options recall invoices , when it is on display click on void. and you are ready to go .
Top Pc America Computers & Internet Experts
Don A
Don A
rosefresh
rosefresh
Rick Rock
Rick Rock
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
