Question about Sanyo Televison & Video
Sanyo dp42647 video goes on briefly then turns off still have sound
Video turns off after a few seconds green light still on and still has audio
  • JOSEPH A VAN CAMP Jun 11, 2012
    how do you release the high current on the board or where should i watch out for it. which capacitors hold the high voltages i don't want to get zapped.
    Sergeant:
  • 246 Answers
If you have sound, do you see a faint picture from an angle? I'm thinking backlight is out. Or the inverter that controls the backlight is out...I'm not sure where the high voltage caps are yet.
Posted on Jun 11, 2012
3 Suggested Answers
SOURCE:
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
Sanyo Vizon 42" DP42647 TV turns on, shows input mode for about a second then goes black,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 23, 2016 | Sanyo Televison & Video
Sanyo dp42647 pwr light but no video or audio
Cable or possibly the source it's connected to.
May 06, 2015 | Sanyo Televison & Video
Sanyo dp42647 picture is black but has good sound worked great yesturday
sanyo lcd dp42647 turns on and has sound no picture black screen
Dec 27, 2009 | Sanyo 42 in. LCD TV
Screen went black on my 42" sanyo model dp42647 lcd
Aug 22, 2009 | Sanyo Televison & Video
Hitachi tv model 50ux58b starts to come then goes off
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Nov 07, 2008 | Hitachi 50UX58B 50" Rear Projection...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
337 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
