Televison & Video Logo
Neil Posted on Mar 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a way to change the region code on a Sony HCD-S300 Please?
I bought my home theater system in the UK but have now moved to Australia. Is there a way I can change the system to play both UK and Australian DVDs? Many thanks.
Anonymous
Level 3:
  • Master 488 Answers
  • Posted on Mar 27, 2012
Anonymous
Master
Level 3:
Answers
488
Questions
0
Helped
231255
Points
1359
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
5 Related Answers
Anonymous
  • Posted on Jul 23, 2008
SOURCE: LG HT302SD DVD Home Cinema System.
the same problem....
Anonymous
  • Posted on Aug 30, 2008
SOURCE: dvd region codes
i have the LH-T360SE model and just wont play any dvds but will play music does any one know how to fix this problem???
my email addy is [email protected] please contact me with any suggestions
thanks
p.s there was a code entered into the player to unlock something that will play all dvds but it never worked now its just not working for any dvd full stop please help
thanks
Anonymous
  • Posted on Dec 30, 2008
SOURCE: I have a lg dr386d
Hey folks, I'm in Melbourne and have the same problem with the LG.
The link at http://www.dvd.reviewer.co.uk/forums/thread.asp?Forum=176&Thread=737213
works fine - just tested it. Make sure you read through the whole thread though, as the first answer isn't right. Look at the second answer from
"tokoloshe"
Anonymous
  • Posted on Jan 24, 2009
SOURCE: SONY BDP-S300 unlock region code
DVD PLAYER SAYS CANNOT PLAY THIS DISC
memturbo
mark gardner
  • 234 Answers
  • Posted on Mar 28, 2009
SOURCE: Region Code crack
sure here ya go
- switch on DVD player
- press eject (tray open)
- press stop
- press 734466
select 0 on OSD for region free
3helpful
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
My region code is region 1.. i bought it in australia and no australian dvd works on it.. only cd's .. what do i do to fix that?
the region code for australia is 4 but im sure you know that if you go into the main menu you should have change reagion code set it to 4
Changing Region Code of Philips HTS9800W (from 4 to 0)
if you go into my computer and right click the device then properties, hardware then double click ur drive and region will be a link at the top set it to your region and your all set. remember you can only change the region 4 times!!
hope this helps
Regio problems
You need to make it multi region. You can either pay for it:
http://www.multiregionupgrades.com/upgrades/panasonic/scht1500.htm
or do it yourself.
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
You can enter these codes with a PocketPC using TV Remote Controller and making a CCF file with these codes. Or use a Palm with Omniremote. Make sure no disc in the player when entering this code.
Please rate this solution if it helps.
Sony DAV-S400 Laser Unit Replacement
where did you get your laser from as i need one for my sony hcd-s300
How to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
