SOURCE: honda eu3000is won't start with starter.
replace the 20 amp fuse that is inline to the starter. you will find it wired in above the battery.
SOURCE: Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
SOURCE: broken pull cord install instructions
Hi there .
The only way to get to the starter on a EU3000IS is from the front of the machine .
You have to remove the plastic around the control panel , remove the control panel and the inverter and you be able to see the starter on the right side . To remove it is only 3 10mm bolts holding it in place . Make sure when you put it back is on the right place and pull the cord gently so the starter can sit .
Hope this help
SOURCE: My honda eu3000 electric start quit working. I
You need to check the ignition plug behind to ensure it is still working fine. You will need a spanner for this and unscrew it anticlockwise.
THanks
SOURCE: Honda eu3000is runs fine with pull cord, but when
Probably the Bendix needs lube. This is the spiral that the pinion gear runs on.
Remove the starter and inspect to insure the pinion gear is in good shape and the bendix is free to move. also verify that the solenoid throws the pinion out to engage.
You can bench test the starter to verify operation.
Also check condition of the ring gear via the starter mounting hole.
