Im having a problem with my hamilton beach water cooler 87330. I do not know whwre to by the Acid Crystals from, but I tried vinegar. My cold water side is not sqirting out water, so i'm assuming that its clogged with minerals. I had the cooler for less than a year. Can you please help me out...
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
I have a hamilton beach hot and cold water cooler model 87330 the hot water works find but the cold water is not cold and the lights stays on what can i do
I am having this exact problem. I cleaned it with vinegar and that worked for a day then the cold water stopped running again. The blue cooling light stays on all the time now. I find if I unplug the entire unit for 10-15 minutes I get cold water again. But it has to be unplugged again later because the cold water stopsrunning. I am going to try the vinegar again, straight this time with now water and let it sit for longer too.
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
Funny, I have the exact same problem. Today I went to pour some cold water, and it only drips. The hot water side is fine, but the cold water side is just dripping instead of pouring out. I tried a pipe cleaner and even turned it upside down and blew as hard as I could down the cold water spout. Nothing helps.
Same Problem:
Model 87330
We have the same problem with our water cooler at the office. We came in today and the hot water dispenser works just fine, but nothing comes out of the cold water side. The cold water light is not on either. HELP! This dispenser is less than a year old.
We have the same problem at our office: the hot water flows just fine, but nothing will come out of the cold spigot.
Cold water started to dribble then nothing at all came out, so I cleaned the entire mahcine, it worked for less than a month and now I have the same issue again.
