My ProHeat system is almost brand new, meaning used albout three times and the last time I used it I didn't do a very good job of cleaning it up. Since then I have cleaned all the suction parts and the solution the the hand tools works fine, but nothing to the floor spray. I have gone as far as to check the spray jets to see if they are clogged.
Once again, the hand tools work fine, but nothing from the floor tools.
SOURCE: bissel proheat 2x main suction problems
on the top of your tank you have a divertor, did you switch this to the floor setting?
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
SOURCE: My Bex Bissell Proheat carpet cleaner refuses to
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rjm
Testimonial: "Many thanks for the link - I'll give their suggestions a go"
SOURCE: My bissell proheat turbo won't
heatman101
