Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook Logo
Anonymous Posted on Mar 26, 2012
The tablet does not recognise my external hard drive
The tablet sometimes recognises and sometimes doesn't
  • Anonymous Mar 27, 2012
    The usb sticks work fine and smooth with the device the device works very well just need help with why it doent recognise e external hard drive all the time.I dont want to have an apple which does not have capability to hold external memory via usb.
  • Anonymous Apr 22, 2012
    Ok so I have my old external hard drive recognised now but it wont recognise the brand new terrabite hard drive.Need to know if it's because of certain brands it will and won't work with.
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Mar 26, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1059463
Points
15385
LOL, why do you think HP sold tablets for $699 for 7 weeks then told all the retailers to get rid of them for $99? Those little things are nothing but trouble unless you're buying an Apple.
Testimonial: "Thanks.I'm just glad that it does actually recognise the 240gb external I plug into it.It's enough memory and power to work everything also have a 32gb memory card in aswell as I use it for work and need the space for music hence the attempt for the terra.I will continue to try with the new updates as the keep coming."
  • I would doubt that a 16GB tablet could recognize a Terabyte drive. It Blows its mind. You could not replace the 16GB internal drive with a drive that big.
How to hard reset ipad air to recognise another apple id
Go to Settings... / General
At the bottom of the list is Reset
You can do a full reset from there.
Why wont windows recognise my ptontotec tablet?
No drivers installed maybe? Find the Ptontotec website and see if the support page has drivers that need installing to your computer before Windows will recognise your tablety thing
I inserted an sd card but my galaxy tablet 2 don't recognise it.
Try un mounting the sd card with the card installed then take it out and teinsert it If that don't work it could be the old format isn't recognized and try formatting it then
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
How do i fix the Malfunction?
Go to the website for the tablet manufacturer and see if there are drivers to download for your computer.
My Archos 10.1 tablet webcam is not recognised
Geezus, why did people fall for these things. Once they go bad, you're limited on trying to get yourself out of hot water.
How do i register so i can go to the android market
I don't think they recognise the archos 7 home tablet.
There's Aptoide and Appslib for getting apps.
Upgrade your filmware at archos as well.
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
2answers
Unable to get pass login window
External HDs are not usually recognised on boot, however some external CD drives are.. although most of these type of devices have a built in recovery partition, which should allow you to restore this tablet back to factory without having to resort to loading from external devices. try pressing f10 or f11 on boot or look for other messages on bootup to press a key combination if all else fails try looking for instructions on factory reset from the manufacturers website
Top Archos Tablets & eReaders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
