If it has a coax fitting on the back connect there. If it does not have (means it is a monitor with no tuner) connect with a/v jacks to the correct input (component?) from a box and select that input to use for watching programs----picture will always be better via rear inputs than coax.
If you have questions press the make a comment button here.
SOURCE: Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a
PDPR06U
if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
SOURCE: pc connect to plasma tv pioneer pdp hd5070
(1) Have you selected VGA Output on the Laptop?
Usually there is a Function Key combination like Fn Plus F7 to send output to the external VGA Port, usually depicted by a monitor icon on the F7 Key
(2) If still no input to the TV, check the TV manual for the frequency of the VGA Input.
For Windows XP Sometimes you have to go into
Control Panel / Display / Settings /Advanced then Monitor Tab
& look at the Screen Refresh Rate.
Suggest you try lowering that value till it produces a signal.
Good Luck
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
SOURCE: Pioneer PDP-r06xe 50 in. Plasma Television
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
