The tension on the thread (not the bobbin) is the same no matter where the tension dial is. The tension is tight enough to break thread fairly frequently. The thread pulls freely until the place just before the thread take up lever (where I assume the tension is applied. On my mom's OLD (read very old) machine, you had to take parts apart, clean out lint and oil things to keep it running smoothly, but I don't see how to take this part of the sewing machine apart and clean the tension portion. I'm assuming this just needs delinting or something. Any ideas how to go about this?
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
SOURCE: sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Robbie
SOURCE: I have this sewing machine and it seems that my
try the tension on 3-5 & see if thats any better,,
you might also check the needle to see if it's damaged or has a burr
it could be a belt going bad
also make sure the top thread is not caught on anything like the spool holder pin or tension disk
check to make sure the thread pulls easily around the tension disk
try rethreading the top thread
sometime the needle & thread are not compatable--try this & see if it works for you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
