There has always been a slight problem with this so and so machine (I had a Singer before but was taken by the embroidery, which I have nevere used) I took it to someone who said they mended brother machines but it came back with the same problem, if not worse. Please HELP a "desperate housewife"!
SOURCE: I have a Brother 98-Stitch
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
SOURCE: oiling Brother Ultima 2001 sewing/embroidery machine
The only place you can opil an ultim is inside the bobbin case and around the bushings in the front end. Do a search for Anns fix it and you will find more than you will ever need for these machines
SOURCE: Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Testimonial: "That was the trick. I knew it had to be something simple but I couldn't figure it out."
SOURCE: cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
