When i turn my ps3 on the green light comes on but nothing will come up on screen of tv and when i try 2 connect my controllers the 4 lights just flash for 5 secs then go off and wont connect. then when i try 2 turn ps 3 off by button at front it does nothing it makes the beeping noise and just stays green.
help me please
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Read the manual carefully. switch pff first then press time on switch to on but hold there for 5 secs . U will hear first beep and then later 2nd beep and by then the setting will switch to standard resolution output and display will come on onscreen
Connected HDMI from ps3 to HDMI input to Panasonic tv, but it just gave me a blank screen. put in a blue ray disc to see if it played - blank screen until very end of movie when menu came up . presed play on controller and screen turned blank again. My panasonic supports 1080i but not 1080p (blueray disc?), but even with a standard dvd in the PS3, the screen was blank.
When i turn my PS3 on...
Everything works fine except the screen stays blank
the lights come on and I hear the beeping of the syste coming on
I was playing GTA IV online and it froze
i turned it off manually and when i tried to turn it back on
the screen stayed blank
nothing comes up on tv when i turn ps3 on and controllers wont connect problem, and notify you when a new solution is offered.
mine wont show up on the screen either the green light will come on but nothing else it wont shut off either and I did reset it and that didn't help
I have the same problem!!
help!!
at first when i saw this problem i switched it on and only my background came up no icons and now nothing comes up black screen
all i had on screen was my coloured background and my controllers wouldnt connect so i did what the first solution said and now i have nothig on my screen
