Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
Rinse does not work
I press the rinse button and the machine does not rinse
Jura impressa f7 decalcifying pressed rinse but does not show empty button as the manual says
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Dec 31, 2010 | Jura Capresso Impressa F7 Espresso Machine
Hello, I have a F&P Smartdrive 5.5 Excellence washing machine. Am I able to reduce the amount of rinses it does? It appears to be performing 2 rinses and I would like to cut it down to one only as we...
Hi just read your posting.Now the 1st rinse cycle is always a spray rinse when the machine is set at the factory.If you follow these instructions then the 1st rinse will be a short spin only,with no water usage.1---Select the OPTION ADJUSTMENT MODE by pressing and holding the START/PAUSE button, then pressing the power button.Then release both after about 2 seconds. 2---Press either SPIN SPEED button to turn on the SLOW light,which is the spin only mode on the 1st rinse. 3---Once the SLOW button is lit push the POWER button to return the machine to normal mode again.Hope this helps and please reply back to let me know how you got on.We are on tank water too but thankfully we have a good bore.Looking forward to your reply and good luck.
Jul 11, 2010 | Fisher and Paykel Washing Machines
Our Gaggia Tianium is stuck on rinse cycle, water pouring out
Just let it run the cycle,don't press any buttons.
When it runs out of water refill it and let it continue.
I get this problem a lot,
Dec 26, 2009 | Gaggia Titanium Espresso Machine
Washing machine will not start wash - just beeps - key on display
Press and hold the Rinse Plus button and wait for the washer to start emitting a tone.
Whilst you are pressing and holding the Rinse Plus button, the tone increases in volume from low to high and then it briefly goes silent, before it starts over agian.
If you release the Rinse Plus button immediately the tone goes silent, then this will turn off the beeping.
If you don't release the Rinse Plus button in time, just continue to press and hold the button and the tone will cycle around again from low to high to silent.
Hope that helps.
Dec 07, 2008 | Audiovox Bosch 718 World Cellular Phone
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Creda W120VW washing machine - Energy & Deep Rinse Buttons. How do they work?
I found the manual on a website which I didn't note down, but which was very useful as it had almost every washing machine manual on the planet! Now I know that the energay saving and deep rinsing buttons are activated by pressing them in. Thanks anyhow for your attempt to help!
Apr 24, 2008 | Creda W120VW Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
76 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
