Reset my computer with gdisc then loaded windows 7. some of the driver are missing or outdated. went to acer and found drivers needed thru driver tuner but need licence key to continue. also tried couple other that ment to be free and need the licence key as well??
SOURCE: need to install pci flash memory driver for acer
install driver max, its a driver software and it has almost all the drives in the world, its free and if ur lucky, u can find ur driver
SOURCE: I need a driver for PCI Device
Chee, its sounds your audio driver is missing that might be listed in PCI section of device manager.
Download chipset (click here), and install it.
Then download audio driver (click here) and install.
The LAN driver also cause this problem, so for LAN driver click here.
You should also try the Video driver, this is here.
I think it will fix your problem.
If any problem just Ask me
Thanks
Iqbal
SOURCE: Acer Aspire 5100 laptop drivers for xp
there should be all the drivers here, just choose the XP listing and then click the driver you want
SOURCE: TSSTcorp CDW/DVD TS-L462C driver needed
Hey,
this should solve your problem
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: I need windows 7 driver to 7 Acer aspire 9500
Now there's an Update from Windows Update, it's listed in the optional Updates
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
http://www.driver-fix.com/scan.php?id=scan5&key=2
note: it will find all of your outdated drivers
hope it helps
