Bosch wff 210l (7 years old)would not spin cycle on Sunday. All else OK then today Tuesday will not wash as well. Machine fills with water and drains water any body any ideas? I suppose I am a reasonably (in)competent bodger but would appreciate direction, apart from the local supplier to buy new machine. Thank you. Good site practical easy to navigate. Craywater.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
I read your reply below Guest. "SERVICE ENGINEER AT THIS AGE APPLIANCE BRUSHES WILL NEED REPLACING IF YOU PUT ON WASH CYCLE AFTER DRUM STOPS FILLING YOU WILL HEAR A SMALL CLICK THIS SHOULD BE WHEN DRUM TURNS IF YOU KEEP HEARING CLICK AND DRUM DOES NOT ROTATE WILL NEED BRUSHES THEY ARE CHEAP TO BUY APPROX 20£" My machine is a bosch maxx wlf2260 & has the same problem, fills, drains but will not wash or spin, the belt is find, Where would one get the brushes & are the difficult to fit? Rgds Paul
If when the spin cycle is turned on and there is a humming sound but there is no movement the belt is the problem.
My washer was 5 years old and it would fill and drain but, I was not washing or spinning. On my washer, between the motor and the transmission was a plastic coupler that had broken. I took the washer apart and fixed within 1 hour and that part cost me $15.00.
Try the capacitor, I had same problem and the capacitor had blown. Try that before trying a new motor!!!!
The GE Frontloader (3yrs old)is the only washer I have ever seen that eats clothes (socks,baby clothes)then it stops spinning untill we take the drum screws out and retrieve them does anyone else have this problem?I think the design or year I have is not even worth a quarter star rating PAIN IN THE ****
THIS APPLIANCE I KNOW WELL AS I WORK AS BOSCH SERVICE ENGINEER AT THIS AGE APPLIANCE BRUSHES WILL NEED REPLACING IF YOU PUT ON WASH CYCLE AFTER DRUM STOPS FILLING YOU WILL HEAR A SMALL CLICK THIS SHOULD BE WHEN DRUM TURNS IF YOU KEEP HEARING CLICK AND DRUM DOES NOT ROTATE WILL NEED BRUSHES THEY ARE CHEAP TO BUY APPROX 20£
VERY LIKELY YOUR PROBLEM IS A BAD MOTOR..
SOURCE: instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
SOURCE: Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
